Volume control issue
Home Forums General discussions Volume control issue
Viewing 1 reply thread
    • #46611
      stingman
      When I turn up the volume a little too much, the emulator crashes and has to be turned off and rebooted to again to function.
      Sometimes my inputs to the emulator are not recognized and nothing happens.
      Stingman
    • #46612
      Hi Stingman
      I can’t remember anyone having the emulator crash when the volume is turned up, does it happen as the volume pot is adjusted or a white afterwards?
      Are you using the volume control on the board or the extension kit?
      As to the emulator not responding to your selections, which emulator do you have?
      What make /model wallbox is it connected to?
      What type of sd card are you using standard size or micro?
      Is the sd configured for any random selections at all?
      Is it always the same selections that fail to play?
